The 7.0.2.6 release includes the below fix, but I’m not sure I know what the intention is. Can anyone explain it, and how we’d leverage this fix when analyzing on these 3 services?
Fix: Unable to manually analyze Disney+/Paramount+/HBO Max videos.
One way I thought it might work is that we can disable auto-analysis and then manually select a later season of a TV series to try to get higher-resolutions showing up as options in the Download window when season 1 of the series was only in a lower resolution, or play an episode in a later season which is basically is “movie mode” where it’s only analyzing a single episode, not multiple seasons.
So how would this fix be something we’d use?
SIDE NOTE: There’s a known issue on HBO Max where analysis of full seasons works, but no matter what episode you select it only downloads episode 1 of the latest season, so for HBO Max that issue could be influencing how “manual analysis” works on HBO, but I’m unable to figure out how to leverage this on Disney+ and Paramount+ that isn’t just replicating “movie mode” analysis and download of a single episode.
