10.com.au does not use DRM encryption. If you are able to use the command terminal, grab a copy of yt-dlp and use that to download from 10play. You need to input your 10play username & password:
yt-dlp -u <your account name> -p <your password> url
If you are not comfortable using the command terminal, find a yt-dlp GUI that supports user/pwd input (not all do). you could try this one: https://whrl.pl/RgXd3a. I’m not a mac user so I can’t vouch for it, but I know the dev.
This doesn’t fix your streamfab issue, but it gives you an alternative way of downloading from 10play. If you are talking about the paid version of 10play, that’s actually paramount+ and it’s another issue.
