just purchased fab, it wont write the entire disc for some reason,I 17:56:54 ImgBurn Version 2.5.1.0 started!
I 17:56:54 Microsoft Windows Vista Home Premium Edition (6.0, Build 6002 : Service Pack 2)
I 17:56:54 Total Physical Memory: 2,029,748 KB - Available: 1,121,864 KB
I 17:56:54 Initialising SPTI...
I 17:56:54 Searching for SCSI / ATAPI devices...
I 17:56:54 -> Drive 1 - Info: MATSHITA DVD-RAM UJ-861H 1.50 (G:) (ATA)
I 17:56:54 Found 1 DVD±RW/RAM!
I 17:56:54 Operation Started!
I 17:56:54 Building Image Tree...
I 17:56:55 Checking Directory Depth...
I 17:56:55 Calculating Totals...
I 17:56:55 Preparing Image...
I 17:56:55 Checking Path Length...
I 17:56:55 Contents: 9 Files, 2 Folders
I 17:56:55 Content Type: DVD Video
I 17:56:55 Data Type: MODE1/2048
I 17:56:55 File System(s): ISO9660, UDF (1.02)
I 17:56:55 Volume Label: AVATAR
I 17:56:55 IFO/BUP 32K Padding: Enabled
I 17:56:55 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
I 17:56:55 TV System: NTSC
I 17:56:55 Size: 4,504,170,496 bytes
I 17:56:55 Sectors: 2,199,302
I 17:56:55 Image Size: 4,504,780,800 bytes
I 17:56:55 Image Sectors: 2,199,600
I 17:56:55 Operation Successfully Completed! - Duration: 00:00:00
I 17:56:55 Operation Started!
I 17:56:55 Source File: -==/\/[BUILD IMAGE]\/\==-
I 17:56:55 Source File Sectors: 2,199,600 (MODE1/2048)
I 17:56:55 Source File Size: 4,504,780,800 bytes
I 17:56:55 Source File Volume Identifier: AVATAR
I 17:56:55 Source File Application Identifier: IMGBURN V2.5.1.0 - THE ULTIMATE IMAGE BURNER!
I 17:56:55 Source File Implementation Identifier: ImgBurn
I 17:56:55 Source File File System(s): ISO9660, UDF (1.02)
I 17:56:55 Destination Device: [0:0:0] MATSHITA DVD-RAM UJ-861H 1.50 (G:) (ATA)
I 17:56:55 Destination Media Type: DVD+R (Disc ID: RITEK-F16-01) (Speeds: 2.4x, 4x, 6x, 8x)
I 17:56:55 Destination Media Sectors: 2,295,104
I 17:56:55 Write Mode: DVD
I 17:56:55 Write Type: DAO
I 17:56:55 Write Speed: MAX
I 17:56:55 DVD+R Reserve Track: No
I 17:56:55 Link Size: Auto
I 17:56:55 Lock Volume: Yes
I 17:56:55 Test Mode: No
I 17:56:55 OPC: No
I 17:56:55 BURN-Proof: Enabled
I 17:56:55 Write Speed Successfully Set! - Effective: 11,080 KB/s (8x)
I 17:56:55 Filling Buffer... (40 MB)
I 17:57:03 Writing LeadIn...
I 17:57:18 Writing Session 1 of 1... (1 Track, LBA: 0 - 2199599)
I 17:57:18 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2199599)
W 18:04:50 Failed to Write Sectors 1492448 - 1492479 - Reason: Peripheral Device Write Fault
W 18:04:50 Retrying (1 of 20)...
W 18:04:50 Retry Failed - Reason: Illegal Mode For This Track
W 18:04:50 Retrying (2 of 20)...
W 18:04:50 Retrying (3 of 20)...
W 18:04:50 Retrying (4 of 20)...
W 18:04:50 Retrying (5 of 20)...
W 18:04:50 Retrying (6 of 20)...
W 18:04:50 Retrying (7 of 20)...
W 18:04:50 Retrying (8 of 20)...
W 18:04:50 Retrying (9 of 20)...
W 18:04:50 Retrying (10 of 20)...
W 18:04:50 Retrying (11 of 20)...
W 18:04:50 Retrying (12 of 20)...
W 18:04:50 Retrying (13 of 20)...
W 18:04:50 Retrying (14 of 20)...
W 18:04:50 Retrying (15 of 20)...
W 18:04:50 Retrying (16 of 20)...
W 18:04:50 Retrying (17 of 20)...
W 18:04:50 Retrying (18 of 20)...
W 18:04:50 Retrying (19 of 20)...
W 18:04:50 Retrying (20 of 20)...
W 18:06:15 Retrying (21)...
W 18:06:15 Retry Failed - Reason: Illegal Mode For This Track
W 18:06:17 Retrying (22)...
W 18:06:17 Retry Failed - Reason: Illegal Mode For This Track
E 18:06:18 Failed to Write Sectors 1492448 - 1492479 - Reason: Peripheral Device Write Fault
I 18:06:18 Synchronising Cache...
W 18:06:28 User opted to skip the 'Close Track/Session/Disc' functions.
E 18:06:28 Failed to Write Image!
I 18:06:29 Exporting Graph Data...
I 18:06:29 Graph Data File: C:\Users\RM's\AppData\Roaming\ImgBurn\Graph Data Files\MATSHITA_DVD-RAM_UJ-861H_1.50_SATURDAY-JUNE-26-2010_5-56_PM_RITEK-F16-01_MAX.ibg
I 18:06:29 Export Successfully Completed!
E 18:06:29 Operation Failed! - Duration: 00:09:33
I 18:06:29 Average Write Rate: 5,537 KB/s (4.0x) - Maximum Write Rate: 9,510 KB/s (6.9x)
I 18:06:32 Close Request Acknowledged
I 18:06:32 Closing Down...
I 18:06:33 Shutting down SPTI...
I 18:06:33 ImgBurn closed!
Id sure appreciate some help, thanks in advance.
