Best DVD Writing Speed
[QUOTE=CBR929;56103]Hi c0afanh
Rule of thumb is 1/2 the speed of your disc, so 8x is fine:D
CBR929[/QUOTE]
I have tried many speeds over the years, The speeds I generally use are 4Ã for single layer media, 2.4Ã for dual layer media. I have never had a bad burn using these speeds. Modern burners do seem to burn better than say 4 years ago and where i occasionally burn at 8Ã for single layer media when burning using my LG "Blue Ray" burner (For some obscure reason my LG burner will not burn single layer DVD's any slower) and have not had any problems.
I have experimented with very slow burn speeds on single layer disks 2-2.4Ã but found that this was as bad as burning on a higher speed 12-16Ã.
Also found that some older players, namely a Sanyo DVD/VHS combi unit anything other than 4Ãdid not play without extreme pixilation.
Used to use the Sanyo for testing any DVD's i burnt (relegated to the attic now) if it played on that it would play on anything.
Use good quality media as has been stated many times on this forum Verbatim (single or dual layer), Taiyo Yuden (single layer), cheap media fails after three to four years, some times seems to oxidise, occasionally coating leaves the disk or starts to pixilate when played.
I think that covers the basics.
