Hi CBR929
I'm close to found the problem here, I'm not sure i'm gonna sleep tonight ;O)
First I get this error ( for all the dvd I try )
error: h264 encode macroblocks per second(33716) exceed the standard(11880), video size(720x400, 29.97), specify profile(0)-level(13)
This is why I post the detail of my PC, because in the new version they use the new CUDA GD encoder (hope they not cap the speed to use CUDA), in v7.0.9.3 they use something else and I had no problem at all (I copy DVD in less then 12 mins) and like you said it's the best software to copy DVD.
Hehehe, by the way I already try to re-install the v7.0.9.3 with my key and it doesn't work, each time I get a popup to upgrade. Sad....
For the rest, now I'm pretty sure it's Avatar, I just analyze the DVD, and there's weird stuff in it, I'm not a DVD wiz, but there's more then the movie on the dvd (by the way it's the real Blu-ray version, the first one with the 2 disc in it, the BD and the DVD (region 1), and I try to copy the DVD)
Anyway again, I'm maybe in the garden looking for something that doesn't exist.
But I always write what I'm thinking (sorry again about the first frustration post) It's only me.
Bill
