For sone reason or other,when i try to copy a dvd to a single layer dvd,the program always prompts me to insert a double layer dvd in the drive whenever the file size is over the 4.7gb size limit.
Even when i set the quality setting to dvd5 before starting the copying process.It works fine for anything under that 4.7 limit but it dosen't seem to want to compress anything over that limit,which is fine from a quality point of view,but if a disc is only say 5gb in size i don't want to use a double layer disc.A little compression is ok.
Is there a fix for this?maybee a setting that i am missing or is this a normal function of the program?i have been using DL discs when this happens but now i would like to fix the problem, if possible,with someone's help.
Thanx for reading this and for your responses.:confused:
