sephiroh im having a same problem too with UP. when i choose the main movie it just keep on analyzing and then finish copyng in seconds and it just keep on repeating the procedure
miguel jimenez [QUOTE=thisdude;5985]Just a heads up. Disney's Up must have new copy protection as nothing seems to work. My Ripitforme program doesn't dectect the disc, DVD Fab and AnyDVD simply scan the disc forever and on my Mac computers the latest jacktheripper software doesn't fare any better either.[/QUOTE] Nothing works for UP, there is no way to copy that movie
miguel jimenez I was able to copy UP I choose tittle 27 movie only disable phatplayer and CUDA, but the movie froze and overall the copy was bad dvdfab almost got it right
AGJ [QUOTE=miguel jimenez;6881]Nothing works for UP, there is no way to copy that movie[/QUOTE] Actually another program can do the movie so I would not say nothing works. Since this the DVDFab forum and I have respect for fengtao, ting and the staff for this forum I can not say what program it is
paul.s Hey AGJ if you know what program works let us know man don't keep secrets i don't think that the dvdfab staff were going to worry about 1 movie that they haven't fixed yet. So please tell us
AGJ [QUOTE=paul.s;6909]Hey AGJ if you know what program works let us know man don't keep secrets i don't think that the dvdfab staff were going to worry about 1 movie that they haven't fixed yet. So please tell us[/QUOTE] this is the DVDFab forum and not allowed to post competitor programs here. You should know that as you have to read the rules when you joined
chris [QUOTE=paul.s;6821]hI i tried what RIP said i'm in canada and the title the dvd player was playing was title 27 but when it was decrypting it said a different title and when finished there was glitches[/QUOTE] This is interesting as UP does not come out in canada untill the 10th of November? How were you able to purchase a copy???:rolleyes:
ripvanwinkle1819 Hey Chris I have to wait until up comes out Nov 10th like everyone else. I merely gave an option because with the last two movies this worked. But I wish I could purchase a copy because that would be great for the kids and great for the staff at dvd fab. :) Sorry no secrets.
Pilago So far, title 27-1 is acceptable for me. Only one little bit freezed, fast forward, then its ok all the way. Compared to other titles (50,52, 33,48, 68, . . .) I wasted burning. Hopefully someone will come up with a better fix.
crazygirl Ok, I have read, and re-read this thread, how do I turn of pathplayer. I have not found this feature yet. Also, Dvdfab is unable to open the source disc, Any Ideas. Thanks
fmijohn theres a green check mark in the upper right hand of dvdfab,click it then go to pathplayer and pick disable pathplayer then ok and restart.
crazygirl thanks, that worked, and my movie has successfully been copied. I found that 27-1 was the movie in the correct order. Thanks for everyone's posts.
phgcpa [QUOTE=crazygirl;7017]Ok, I have read, and re-read this thread, how do I turn of pathplayer. I have not found this feature yet. Also, Dvdfab is unable to open the source disc, Any Ideas. Thanks[/QUOTE] OK...I have read and re-read this thread, how do I get this DVD copied?
Pepper27 Hey All, The first thing I tried was disable pathplayer and ignore all errors and still not able to do this one. It starts scanning the disc and after a minute or two it shuts DVDFab down.
fmijohn so did any body else that used title 27 have problems like i did where it would stop then play and look glitchy
bean55 Turn PathPlayer Off Click on Main Movie , insert disc, depending on how powerful your system is and what drive you have will determine how long the disc will scan.USA Region 1 look for Title 27 There are 3 of them testing to find out which one now.
fmijohn i did that but when i made my dvd.i put it in my dvd player but it stopped then would play.it did not look good
