[SIZE="3"]Starting with DVDFab v10.0.3.0 Beta, to remove the DRM of Apple contents is now supported![/SIZE]
Q: What's DRM?
A: DRM is the file protection. The file could not be played back on the other players, and could not convert to the other format.
Q: Do I need to do something before using DRM Removal?
A: Yes, install iTunes and authorize your computer with your Apple ID is needed.
Q: What can do in DRM Removal?
A: Remove the drm of apple movies, TV Shows, Rented and Apple Music, and the output files can be played back on any other players.
Q: Can I have a trial for DRM Removal before buying?
A: Yes, 1 movie and 5 songs in 30 trial days.
Q: What kind of format is output after removing DRM?
A: For movies, M4V format, it's lossless and same as source, and will also keep the AC-3 audio, cc subtitles etc.
For Music, M4A format, it's lossy compress.
Q: How to add source in DRM Removal?
A: For Movies, you can add files from Windows Explorer and Add from iTunes(DRM Removal will load the iTunes library).
For Music, Add from iTunes only.
To load the iTunes library, please enable the option "Share iTunes Library XML with other applications" in iTunes. Edit -> Preferences -> Advanced.
Q: Do I need to purchase DRM Removal if I have Video Converter or Creator? Is it included?
A: Sorry, it is not included and must be purchased as standalone module.
Q: What to do if my movie or music failed to remove DRM?
A: Please tell us the movie name and song name if the file can be played back on your iTunes.
