DVDFab Forum - Editing .nfo file to add info for movie collections
instagram takipci satin al - instagram takipci satin al mobil odeme - takipci satin al
bahis siteleri - deneme bonusu - casino siteleri
bahis siteleri - kacak bahis - canli bahis
goldenbahis - makrobet - cepbahis
cratosslot - cratosslot giris - cratosslot
istanbul escort - çapa escort - şirinevler escort - avcılar escort - şişli escort - avrupa yakası escort - şirinevler escort - halkalı escort - beylikdüzü escort - mecidiyeköy escort - ümraniye escort - adana escort malatya escort
film izle - film izle
    General Question Editing .nfo file to add info for movie collections
    I'm wondering if there is a line of code I can add manually to an .nfo file to tell it is part of a collection, such as the Harry Potter movies so that my DVDFab Server will pick it up automatically. I know there is a feature in the server to add custom collections, but anytime I have to rebuild the library I loose them all. Right now the only collection that my server picks up is the Matrix and it is the only 3 movies in my entire server that have no .nfo files in there folders. All my other movies that are part of collections the server does not seem to find and there are quite a few. Thanks for your time with this inquiry!!
    Is there anything I can do to get DVDFab Server to pick up on a movie collection automatically?
      Is the collection you want defined in TMDB (The Movie Database)? The movie server gets its meta data from that database. If the collection is not define there, you won't get it in the DMS. If this is the case, the easiest thing is to use a custom collection.
      I have not experienced any problem with the DMS not creating a collection if it is in the TMDB. However, that may be because I do not normally use nfo files. I have found that using the standard naming conventions for files give me 95% scraper accuracy with no nfo file. I only make use of nfo files on the rare occasion that I have to do a "fix match" to get the meta info correct. (This happened to me for 1 STAR WARS movie and it did not get added to the collection automatically. I had to add it manually using the menu feature in the DMS)
      If the collection is in the TMDB and not showing up, you might try removing the nfo file for those movies (assuring that they are named correctly) let the scraper add them and see if that make the collection appear. It may be the nfo overiding the scraper causing the problem.
      I do not believe there is an nfo tag for defining a collection, but you could check the KODI web site to verify that.
        Thanks for the info much appreciated!!
