PAL Speedup Fix
    DVD Copy PAL Speedup Fix
    This might already be possible. But if it is I don't know how to do it. But one of the issues with PAL DVDs is the framerate is 25 FPS. Whereas NTSC is 24FPS. This means PAL speeds up the video causing a higher pitch when people talk.
    I would like to be able to recode a PAL DVD and fix the PAL speedup on the video and sound but not cause any other issues.
    As I say it may be possible in DVDFab already but when you google solutions to this they are elaborate taslks utilising a whole list of programs to do what should be simple.
    If there was a button to select "fix PAL speedup" and then DVDFab would convert a DVD ISO to MKV and fix this issue It would be fantastic
