Anyway for DVDFAB to copy VCDs?
    Hi all,
    Good day to all.....
    1) I want to know if it is possible for DVDFAB to copy VCDs? So that it can be played on player. I have been trying it but in vain.
    2) Are the copy-protection in DVDs and VCD the same? Can DVDFAB Remove VCD copy protections?
    3) I could only convert a VCD (file to Mobile) using .DAT, but it seems there are some problems with certain VCDs....when converting, the system & DVDFAB hangs. (don't know if the Copy-protection in VCD is stopping the process).
    4) Most VCD has dual languages features (ie :- Left side in English and Right side in other langauage). Can DVDFAB be able to remove one of the langauages.
    Thank you
    U can run....but U cannot hide
    "I am the ONE & ONLY....You better remember that!!!"
    1. No - You can use any normal CD Burning software and just copy the disk.
    2. No & No.
    3. Copy VCD to a folder on your HDD first and you will see if the problem is actually read errors on the VCD.
      do what GregiBoy said as the VCD's I have seem to not have copy protection and I have a lot since I go to the Philippines every year to visit family
