Greetings,
I did my best to search for an answer to this question both on this forum and others with no success. My goal is to identify the differences between Blu-Ray Ripper and Blu-Ray Copy.
Currently, I have a lifetime subscription to DVD-Copy. It works great. I can use it to copy the contents of a DVD to my hard drive, and from there, I use the latest version of [other software] to convert it either for my iPod Touch, or to an MP4 playable through my Blu-Ray player's USB port.
It sounds like BD Ripper functions bother as a copier and converter, eliminating the need for [other software]. However, in order to convert, it must copy as well. In other words, it appears that BD Copy will copy the disks, and BD Ripper will copy AND convert, which doesn't explain why they cost the same.
In short, why would anyone purchase BD Copy, if BD Ripper has the same functionality - and then some?
Any info would be greatly appreciated, thanks.
