[QUOTE=signals;144004]From within DVDfab:
Click the Copy button, then click the little "+" button where it says Source, then click on the Clone/Burn button.
You can also use ImgBurn in standalone mode to build the images and burn them to disc. You also should update DVDFab to v9047.[/QUOTE]
When I click the little "+" button, it pops up a "open Directory" window. At the bottom it says file types and I can select .img, .ini, .iso, .nrg. This is confusing because I have vob files, what gives? Am I at the wrong spot or is this an oversight on the program developer?
If I select the video_ts folder, it gives me a warning telling my this is a video folder or something.
