password log in problem
    Other password log in problem
    Im trying to update the blueray ripper with the password that i had didn't work so i contacted them and they sent me a new password still didn't work. even with out the new update it will not allow the blueray to open.
    Are you certain you are using the correct email address? Can you log in at the Member Center on the DVDFab website (https://www.dvdfab.cn/member.htm?dla...rackID=forum)? The Member Center can send you a new password to your registered email address (just click the Forgot Password button).
    Who sent you the new password?
      someone who responds to instant messaging on Facebook.
        I have sent you a new temporary password via forum PM, please kindly check, if still have problem, please reply the PM.
        Regards,
        Mona
          I have forgotten my password for my dvdfab application and having problems finding it can you help Thanks
            Please send me your registered email info via PM or send to my email, I will check for you.
