NVIDIA GeForce GTS 250 is quite old. In this case, 25 minutes to analyze then copy the DVD content is normal.
When ripping, we would suggest you to use passthrough profile, or you can check if there is driver update available, do the update to see if it will make a difference.
To get better performance, we would suggest to get a better video card or use a PC with higher specs.
