OK, so I think i need a new BR drive, i keep getting read errors of several BR discs. I'm currently using An LG model BP50N40. Please give me your OPs of a better BR drive
DVD drive
The DVDFab developers recommend these drives:- LG WH16NS40 (internal, SVC code: NS50) Tested
UHD friendly drives:- LG WH14NS40 (internal, SVC code: NS50) Tested
- LG BH16NS40 (internal, SVC code: NS50) Tested
- LG BH16NS55 (internal) Tested
- LG BH14NS58 (internal) Tested
- LG BH16NS58 (internal) Tested
- LG WH16NS58 (internal) Tested
- LG BE16NU50 (external, USB) Tested
- ASUS BC-12B1ST b (internal, manufactured 2015+)
- ASUS BC-12D2HT (internal, manufactured 2015+) Tested
- ASUS BW-16D1HT (internal, manufactured 2015+) Tested
- ASUS BW-16D1H-U (external, USB, firmware version starts with letter A, manufactured 2015+)
- LG BU40N (slim, USB or laptop: Fujitsu, Dell, Nec)
- Buffalo BU40N (external, USB) Tested
- Archgon MD-8107S-U3-UHD BU40N (external, USB) Tested
- hp HLDS BU40N (internal, laptop: HP)
- LG BU50N (internal, laptop: Lenovo)
- hp HLDS BU50N (internal, laptop: HP)
- LG WH16NS60 (internal, recommended) Tested
The firmware on some of the above models will not support 4k UHD discs without a firmware change, which can be done with the DVDFab UHD Drive Tool. I use the LG BH16NS55 and BH16NU50. You can find many of them on ebay with the firmware already fixed for 4k UHD, just search for "UHD Friendly". Even if you are not currently interested in UHD discs, most of these drives offer superior performance on Blu-ray and DVD since they have the mechanical tolerances for supporting 4k.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
