8 Bit e 10 Bit (HDR10, SDR, Hevc 8 Bit, Hevc 10 Bit.........)
    Hello, the 8-bit encodings (x265 and x264) with increased brightness has problems with color inconsistencies or "black" backgrounds and asks me if there is any way to avoid these inconsistencies because I had to use the command line to remove them and I sent you in the "Bluray Ripper" the characteristics used and therefore maybe they can be useful to fix the 8 Bit encoding "hevc", I think you just have to integrate the following parameters ( hevc - 8 Bit e 10 Bit "--aq-strength 2.00 --psy-rd 1.00") (HDR10 4k e HDR10 1080p - "--psy-rd 2.00 --aq-strength 0.70") and maybe "--strong-intra-smoothing and aq-mode"
    I have passed your post link to the developer in charge. Thanks.
      Preset very slow:
      --b-pyramid --lookahead-slices 0 --no-rect --no-amp --tu-inter-depth 3 --tu-intra-depth 3 --limit-tu 0 --strong-intra-smoothing --max-merge 3 --limit-refs 3 --limit-modes --me uhm --subme 4 --temporal-mvp --weightp --weightb --psy-rd 1.00 --aq-mode 3 --aq-strength 2.00 --no-cutree --no-early-skip --rskip --sao –signhide --
      Prest medium/slow:
      --b-pyramid --lookahead-slices 5 --no-rect --no-amp --tu-inter-depth 1 --tu-intra-depth 1 --limit-tu 0 --strong-intra-smoothing --max-merge 3 --limit-refs 3 --limit-modes --me uhm --subme 2 --temporal-mvp --weightp --weightb --psy-rd 1.00 --aq-mode 3 --aq-strength 2.00 --no-cutree --no-early-skip --rskip --sao --signhide --
        your mean if "with increased brightness " in editor ?
        hould use --aq-strength --psy-rd for better picture.
          I am doing various tests, maybe I also have to vary color-prim, matrix color ... Etc
