Twitch problem
    Twitch Twitch problem
    Hi guys,
    When I click on the Twitch on the Live Streaming section, not thing happens, won't open a window as it does with Tokyo2020 icon, and sometimes I get the error in the incl. screenshot. Any suggestions?
    In advance, thank you.
    The (mini) Error message say: DRMDownloader.exe - Entry Point Not Found
    If I start DRMDownloader: Entry Point 'cef_visit_web_plugin_info' not found
    checked with pedump shows that should be in libcef.dll - but is not:
    Click image for larger version  Name:	libcef.jpg Views:	0 Size:	96.0 KB ID:	434867
    It's the same with me: Nothing happen (and no log entry)
    Any suggestions?
    Use this url in SF/Browser: www.twitch.tv/p/en/watch/​
      Jack/Mona/Wilson, without a doubt this needs to be referred to the Developer. Good work, Germania!!
      I'm in the process of downloading the latest release of CEF just to see if the libcef.dll in it contains the missing function. More later.
      Germania, which pedump are you using?
        online pedump.me
          online pedump.me
          Oh, thank goodness. I was trying to use PeBytesF and I don't know what it was trying to do. I see what you found, but did you also see that it lists qbcore.dll in addition to libcef.dll? I can't find that anywhere on my computer. I looked it up, and it supposedly is a .dll from Grand Theft Auto V. Strange!
          StreamFab is currently using CEF 102. I searched the libcef.dll from the latest CEF, which is 120. 'Cef_visit_web_plugin_info' is still not a part of it. This is definitely one for the Developer.
            I was also wondering about qbcore.dll (Tencent Browsing Service) ..
            .. have found an outdated version with 'cef_visit_web_plugin_info'
            But DRMdownloader shows the same error and "regsvr32 qbcore.dll" failed
            After some "Loudermilk" ... my results:
            'cef_visit_web_plugin_info' was removed in libcef.dll v100
            older version have this - but then this errors follows:
            libcef.dll v90 missing: "cef__downloader__media__create"
            libcef.dll v96-99 missing: "cef_register_widevine_cdm"
            But current v102 have also no "cef_register_widevine_cdm"
            So I think DRMdownloader.exe is currently unused/useless (?)​
              Excellent, excellent bit of research.
              I don't remember when StreamFab went up to CEF 102. I don't think it was too long ago. So, that might be the answer as to why this recently appeared. Not that Twitch is a very active streamer here and is written about often. In fact, I don't remember any other messages about Twitch in the last two years.
              I would imagine that they'll probably stay with 102 (or up to 109) for a while. CEF 110 can not run under Windows 7 and 8, and I think there are still quite a few people that run that here.
                This is a known issue. It is in the to do list.
