Problems with login and quality of downloading videos from onlyfans
    OnlyFans Problems with login and quality of downloading videos from onlyfans
    Hi, I have version 6.1.9.4 and the downloads are not downloading in full HD. It turns out that 3 days ago the login screen appeared blank and I couldn't log in. Today, August 20, they fixed the login screen but the video downloads dropped to 240p. The download no longer works in maximum quality.
    OK i've my first account for testonly ..
    .. without subscription it is apparently only a few seconds
    But this is offered and downloaded in 720p
      Germania Bro, I also use Stream Fab in that version, but it no longer downloads in full HD and I don't understand your answer. I see the same Stream Fab program and the same version. Please could you be more complex in your explanation?
        As I wrote before, this is my first account.
        I have no idea if and what is or was offered in FHD ...
        ... but I can download the maximum that is offered to me
        in the browser (without subscription) without any problems with SF
        If that doesn't help you - sorry, that I only signed up for this test​
          Ok my friend, thank you for participating and your opinion, for now it is urgent that the company fixes this, I have been using the product for months, what you are telling me is a download module for onlyfans and streamfab already has it in its full version, 3 days ago it failed in other ways on onlyfans and it is important that the company reports it as well.
ID:	448818The problem only occurs with DRM protection, not with normal downloads. As you can see, there are no higher qualities in DRM, the result is a video with a quality of 240p.
            Click image for larger version  Name:	Ashampoo_Snap_2024.08.20_16h42m24s_002_.jpg Views:	0 Size:	22.3 KB ID:	448817
              I believe you immediately
              Unfortunately I didn't know beforehand that I can't access
              DRM-protected videos (free sample) without a subscription.
              At least I now know that the login problem (for which 2 topics already exist) was not caused by SF​
                correct germania now I feel frustrated because I used the program to download videos with DRM right now I don't know if stream fab will have a solution regarding this in a few days, I hope so for me it was really important.
                  For my side, it's download it in 720p but then, failed.
                  Here is my log file.
                    I can't promise that it would be helpful ...
                    ... but I don't see a StreamFab.log​
                      You should create a separate thread. Your error is different from mine. I want an answer about the download failure but with DRM, not normal downloads.
                        I am also seeing the problem with only downloading the lowest available quality for DRM content on OF. I suspect OF has changed something, and the StreamFab dev(s) will need some time to work out how to deal with that change.... assuming anyone is paying attention.
                          Should they be any help with this low resolution only problem, here are the two (I think relevant) log files.
                            I see the mpd url - but can't access because token is for 30min expired ..
                            .. and probably same ip from Netcom required
                            If I see this correctly, Sophia wants $4.50 per month (Limited offer - 70% off) - no way​
                              Please send a message to support, it's better this way so they know there's a problem. I think they haven't realized that the forum here is just to help each other, but this particular case should be handled by the streamfab developers.
                              Let's help each other and send messages with the specific problem, that the problem is with low resolution DRM downloads, at the following link:
                              DVDFab contact page in order for you to contact our specialist for any problem you might encounter while using DVDFab, the fastest DVD to IPOD conversion software.
                              This is the official technical support.
                              A message arrives to their emails and redirects them to talk to technicians and report the problem.​
