Unifab 2.0.2.1 Not Using Saved Output Directory
    Currently using 2.0.2.1 but this has been an ongoing issue for several versions now.
    I keep loading this app up to see if it's improved or not, and while it's getting there there has been one issue that maddening as hell now.
    I have a folder I want to use for conversion Output.
    This has always been working fine until 5-6 versions ago or so. Since then, it keeps putting outputted files into a subfolder of my chosen location titled "Converter"
    No matter how I set the app for the folder, it constantly uses a subfolder of "Converter."
    Choose a new output folder entirely? It creates a "Converter" folder in the new location.
    How the hell do I stop this?
    Thank you for your report. We'll test on our end.
    UniFab forum has been migrated and the new forum is located at: https://community.unifab.ai/
      How about this issue?
      We're now on version 2.0.2.7 and this is STILL an issue.
      This used to work fine until 2.0.1.5 or 2.0.1.6 then started putting conversions into a converter folder instead with no way to change it.
      That's now 11 or 12 versions with no fix and no word on it either.
      What the hell, guys?
        Sorry for this kind of delay, we'll remind the relevant department about this issue.
          It's been 11 days, and we're now on 2.0.2.9 and it's STILL using a "Converter" folder inside the folder I actually want the files placed into.
          Is anybody working on issues on this program?
            It's been 9 more days.
            We're now on version 2.0.3.0
            It is STILL using a "Converter" folder inside the folder I actually want the files placed into.
            This is turning into a joke now and I'm going to start actively telling people to avoid this program because it's buggy and no one cares about the issues enough to fix them.
