This has been happening to me to me as well.
The past few version have resulted in every TV series completing their download, BUT, up to half of the episodes are out of sync. The most recent one I tried to download was Judge Judy Seasons 1 and 2. About 175 of the episodes were out of sync so I had to delete them and try again to download the bad ones. On that attempt, most of the episodes were out of sync. Though, some episodes completed all the way. I have to keep repeating that cycle until I get all the episodes to DL (doesn't always work) That has been for ANY TV series I download from Pluto from the past few versions.
With the latest version of SF I tried 6.1.1.9, the JJ episodes won't even complete. One episode should be 325-350 MB but they only DL about 4 to 5 MB then quit.
Some of the other series that had the same issues:
Family Ties
Wings
Taxi
COPS
Diagnosis Murder
The Odd Couple
I usually check all DL's with MediaInfo to make sure there is an audio track for every episodes, BUT, it doesn't always mean that the audio is OK just because it shows an audio track.
I'm not about to manually go through 350 (or even 100) episodes for a series, so what I do is sort the folder by file size. If I see there is a big difference in file size, then I can see where to start checking for bad audio. It only takes checking a few to see which ones are bad then I can delete all of those and try again.
Also, a file that is unusually large compared to the others, I found, is often bad as well. Usually the video gets stuck at a certain point for a long time before continuing and throws everything off.
This has been mainly with Pluto, but occasionally, I will get it from other DL's, like Daktari on Roku.
