Temporary solution for some unanalyzable problems
This topic has been answered.
    From Developer Temporary solution for some unanalyzable problems
    Hi all,
    To users who have issues with Skyshowtime/OnlyFans/Channel4/Peacock/Crackle, please try this temp solution.
    1. Download the CEF file from the following link: .
    2. Extract the CEF file to the directory %userprofile%/AppData/Local/. and overwrite the CEF directory.
    3. Restart StreamFab and try again.
    We are still checking that why the files are missing, but we will add to check the files for the problem in next version.
  • Answer selected by Cats4U at 01-26-2024, 01:22 PM.
    Please, everybody, do not try replacing the WidevineCDM yourself. It will not work and could potentially interfere with any fix that StreamFab makes in the future. CDMCats.zip was an attempt to temporarily solve a problem at the time of its release. It will NOT solve anything now, and could possibly do much harm.
      Thank you, Wilson!
        Solution works like a charm. Thanks!
          Thanks this temporary fix works ! Thanks Wilson
            Thanks Wilson - I got really excited but no joy here on my Mac:
            1. Shutdown SF
            2. Replaced the CEF directory in my %userprofile%/Library/Caches directory
            3. Added the CEF directory to my %userprofile%/Library/Application Support and %userprofile%/Library/Preferences directories
            4. Restarted SF - nothing DLd from Channel 4
            5. Rebooted Mac and restarted SF - still nothing DLd from Channel 4
            Have I put the CEF directory into the wrong place(s) on my Mac?
              I guess "temporary" really does mean temporary. I replaced the CEF directory yesterday and it solved the problem. I tried a download this morning and ran into the same endless analyzing issue. I replaced the CEF directory again and everything was fine.
                that worked for my peacock problem!!
                  Ditto! Thank you so much!
                    Thank your very much Wilson, fixed my Peacock issue.
                      This fix correct all my problemes, so Canal+ and DRM MPD work again for me
                        1. Shutdown SF
                        Anyone got any helpful thoughts about my Mac issue?
                        TiA
                          Thank you, Wilson as your listed fix worked for me and my Peacock issue.
                            Guess what, it didn't log out, after downloading a movie and opening and closing. That is what I call progress.
                              Attached is my version of CEF.7z which I call CDMCats.zip. It ups Widevine to the latest release which is 4.10.2710.0. CEF.7z uses 4.10.2557.0 which is two versions behind the latest.
                              Instructions:
                              Turn off StreamFab
                              Make a backup of %userprofile%/AppData/Local/CEF
                              Delete the CEF folder from %userprofile%/AppData/Local/
                              Extract CDMCats.zip to %userprofile%/AppData/Local/
                              Start StreamFab and download a video (preferably from Peacock or one of the previously affected streamers)
                              Usual disclaimers -
                              Only make this change if you know what you are doing.
                              It works for me, I don't guarantee that it will work for you.
                              This is not an official DVDFab release and may interfere with official DVDFab releases later.
                              I don't have any money so don't bother suing me
                              If things go wrong, delete the CEF folder and install your backup.
                              Please download from this link -- CDMCats.zip
                                Thanks Cats4U - is this for Windows only?
