Problems with Amazon, Max just stuck at Analyze
    StreamFab for Windows Problems with Amazon, Max just stuck at Analyze
    I have tried to download from Amazon and Max. All that StreamFab will do is go into an analyze loop and not do anything else. In fact, I've had to use task manager to finally exit the program as it wasn't stopping after telling it to stop or pause. I deleted log file but didn't help. Anyone else running into this? I'm running version 6238. I'd put the zip file up but the system tells me it has timed out and I must log in....I'm logged in! System is out of whack too.
    It is extremely unusual to have the same problem with multiple modules, especially when no one else is posting about these problems. Personally, I suggest you start over with 6238 and follow the directions exactly as written in the Stickie section of this forum on how to do a Clean Install.
      Having the same problem with Max for last several updates. I've tried doing complete uninstall, data delete, and clean install. Still hangs at analyzing.
        Are you also getting stuck analyzing with Amazon? That is what this topic is about, both Max and Amazon modules. If you are only having the problem with Max, either start a new topic or search for a recent topic concerning Max getting stuck analyzing and post there. In either event, please attach a fresh copy of your StreamFab.log.
          If you are seeing what I am saying, it's not stuck on analyze. I just opened a thread on the topic. It is not stuck, it just looks like it. Just give it the normal amount of time you did with previous versions. It is working.
          Tried on multiple providers, the download window always says "Analyzing" throughout the entire process. As a result I never see the download itself happening, and the download speed meter always says 0. On NF it kept toggling between Processing and Analyzing every half second or so. On AMZ, it alternated between
            I'm just having problems with max, prime is working fine. Max hangs at analyzing, have legit run for 20 minutes and never stopped.
              If nothing happens in 3 minutes - there is no point in waiting any longer
              Title, country and settings unknown - so no help is possible
                You're going to make me repeat what I previously wrote?
                I don't see any new Max topics from you or any additional posts added to an existing Max topic that concerns endless analyzing. As it stands now, it looks like you are hijacking Isrdude's topic which is against forum rules.
