Atmos+TrueHD/AC3 Core track is missing in output...
Output:
More stranger eac3to info:
dvdfab_internal.log
Code:
Format : BDAV Format/Info : Blu-ray Video File size : 58.1 GiB Duration : 2 h 31 min Overall bit rate mode : Variable Overall bit rate : 54.7 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : 6 Duration : 2 h 31 min Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.709 Mastering display luminance : min: 0.0020 cd/m2, max: 1000 cd/m2 Video #2 ID : 4114 (0x1012) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : 6 Duration : 2 h 31 min Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.709 Mastering display luminance : min: 0.0020 cd/m2, max: 1000 cd/m2 Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Codec ID : 129 Duration : 2 h 31 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 695 MiB (1%) Language : Czech Service kind : Complete Main Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : TrueHD / AC-3 Format profile : TrueHD+Atmos / TrueHD / AC-3 Codec ID : 131 Duration : 2 h 31 min Bit rate mode : Variable / Constant Bit rate : 640 kb/s Maximum bit rate : 5 853 kb/s Channel(s) : Object Based / 8 channels / 6 channels Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : / 48.0 kHz / 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Stream size : 695 MiB (1%) Language : English Service kind : Complete Main Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 11 s 53 ms Language : Czech Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 2 h 31 min Delay relative to video : 11 s 53 ms Language : Czech
Code:
Format : BDAV Format/Info : Blu-ray Video File size : 51.8 GiB Duration : 2 h 31 min Overall bit rate mode : Variable Overall bit rate : 48.8 Mb/s Maximum Overall bit rate : 109 Mb/s Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : 36 Duration : 2 h 16 min Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.709 Mastering display luminance : min: 0.0020 cd/m2, max: 1000 cd/m2 Video #2 ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Commercial name : HDR10 Format profile : Main 10@L5.1@High Codec ID : 36 Duration : 2 h 31 min Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.709 Mastering display luminance : min: 0.0020 cd/m2, max: 1000 cd/m2 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Codec ID : 129 Duration : 2 h 31 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 695 MiB (1%) Service kind : Complete Main Text #1 ID : 4768 (0x12A0) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 11 s 54 ms Text #2 ID : 4769 (0x12A1) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 2 h 31 min Delay relative to video : 11 s 54 ms
Code:
eac3to 1) 00000.mpls, 00000.m2ts, 2:31:52 - Chapters, 31 chapters - h265/HEVC, 2160p24 /1.001 (16:9) - h265/HEVC, 1080p24 /1.001 (16:9) - Dolby Vision Enhancement Layer - AC3, Czech, multi-channel, 48kHz - TrueHD, English, multi-channel, 48kHz eac3to 1) M2TS, 2 video tracks, 1 audio track, 2 subtitle tracks, 2:31:52, 13.017p 1: Chapters, 31 chapters 2: h265/HEVC, 2160p24 /1.001 (16:9), 10 bits 3: h265/HEVC, 1080p24 /1.001 (16:9), 10 bits - Dolby Vision Enhancement Layer 4: AC3, Czech, 5.1 channels, 640kbps, 48kHz, dialnorm: -28dB 5: Subtitle (PGS), Czech 6: Subtitle (PGS), Czech
Code:
0m 28.17s: Source manager: add source id 0. 0m 28.19s: info, try to open file D:\00007.m2ts 0m 28.81s: warning: audio info: index 2, codec_id 86019, channels 6, bitrate 640000, sample_rate 48000, format 8, bit_per_sample 0, frame_size 0 0m 28.81s: warning: audio info: index 3, codec_id 86061, channels 8, bitrate 0, sample_rate 48000, format 2, bit_per_sample 0, frame_size 0 0m 38.82s: warning: audio info: index 4, codec_id 0, channels 0, bitrate 0, sample_rate 0, format 8, bit_per_sample 0, frame_size 0 0m 38.84s: info: open successed, iformat = MPEG-TS (MPEG-2 Transport Stream) 0m 38.94s: Source manager: open successful. 0m 39.48s: Work manager: create creator work 0 with source 0 and uiinfo 0. 0m 39.49s: ========WorkAttr::SetSource======= 0m 39.49s: Source Video Size Original: 3840 x 2160 0m 39.49s: Source Video Size Display: 3840 x 2160 0m 39.49s: Source Video FPS: 24000 / 1001 0m 39.49s: Source Video Bitrate: 1200 0m 39.49s: Source Audio Bitrate: 640000 0m 39.49s: Source Audio Channels: 6 0m 39.49s: Source Audio Volume: 100 0m 39.49s: Source Audio Bitdepth: -1 0m 39.49s: Source Audio SampleRate: 48000 0m 39.49s: Work Profile: BD_PASSTHROUGH 0m 39.58s: Source manager: open source flag:1,0,1,1,1 1m 18.30s: UILog: OnMsgToolbar_Start 1m 18.31s: UILog: Msg Start: ready start 1m 18.35s: UILog: btn Visible: left btn 4 right btn 9 1m 18.35s: UILog: Msg Start: start test run work 1m 18.35s: UILog: Msg Start: run work 1m 18.35s: UILog: Run current Work. 1m 18.35s: UILog: Begin Work Creator 1m 18.36s: OPList for video: (0.1),(1.1),(2.1),(3.1),(5.32),(6.32) 1m 18.36s: Video Converter check watermark flag: 0 1m 18.36s: UILog: start running at thread. 1m 18.38s: UILog: 0x927a6c0 work ctrl status 3->0 1m 18.38s: UILog: return flag at start running at thread ok. 1m 18.39s: Menu template name: No menu 1m 18.39s: Output disc type is: BD100 2160p 1m 18.39s: UILog: 0x927a6c0 work ctrl status 0->0 1m 18.43s: BD Author: no menu 1m 18.43s: info: prepare convert data for clip(00000.m2ts) 1m 18.44s: info: crop value after clone: left = 0 right= 0 top=0 bottom=0 enable=0 mode=0 1m 18.44s: info: use profile(BD_PASSTHROUGH) 1m 18.44s: info: file (m2ts) 1m 18.44s: info: 3D working_mode(disable), 3D format(sbs_lef_right) 1m 18.45s: UILog: btn Visible: left btn 4 right btn 9 1m 18.45s: UILog:MsgWork:WorkStatus_Start 1m 18.45s: info: min_bitrate_kbps(30000) max_bitrate_kbps(60000) optimization_bitrate_kbps(30000) 2m 42.50s: info: analyze hd audio success 2m 42.51s: info: convert work begin for clip(00000.m2ts) 2m 42.51s: info: UILog: work status: Notify 1 1 -1 not 2m 42.52s: info: stream input@ Video(4113)[codec(hevc) size(3840*2160) fps(24000/1001) interlace(0) duration(9111)sec opcode(copy) fmt(72) profile(2) level(153)] 2m 42.53s: info: stream output Video(4113)[codec(hevc) size(3840*2160) fps(24000/1001) interlace(0) bitrate(0) duration(9111)sec fmt(72) profile(2) level(153)] 2m 42.53s: info: stream input@ Video(4114)[codec(hevc) size(1920*1080) fps(24000/1001) interlace(0) duration(9111)sec opcode(copy) fmt(72) profile(2) level(153)] 2m 42.53s: info: stream output Video(4114)[codec(hevc) size(1920*1080) fps(24000/1001) interlace(0) bitrate(0) duration(9111)sec fmt(72) profile(2) level(153)] 2m 42.54s: info: stream input@ Audio(4352)[codec(ac3) channels(6) sample(48000) bitrate(640000) bitdepth(0) opcode(copy)] 2m 42.54s: info: stream output Audio(4352)[codec(ac3) channels(6) sample(48000) bitrate(640000) bitdepth(0) opcode(copy)] 2m 42.54s: info: stream input@ Audio(4353)[codec(truehd) channels(8) sample(48000) bitrate(0) bitdepth(0) opcode(copy)] 2m 42.54s: info: stream output Audio(4353)[codec(truehd) channels(8) sample(48000) bitrate(0) bitdepth(0) opcode(copy)] 2m 42.54s: info: stream input@ SubPicture(4608)[codec(pgssub) language(Czech) opcode(remux)] 2m 42.54s: info: stream output SubPicture(4608)[codec(pgssub) language(Czech)] 2m 42.55s: info: stream input@ SubPicture(4609)[codec(pgssub) language(Czech) opcode(remux)] 2m 42.55s: info: stream output SubPicture(4609)[codec(pgssub) language(Czech)] 2m 42.55s: info: SubMode(Remux) -- Display Only forced Subtitle(false) 2m 42.56s: UILog: btn Visible: left btn 4 right btn 9 2m 42.56s: UILog:MsgWork:WorkStatus_Start 3m 14.18s: info: Find Forced Subtitle Stream : PID(4608), Language(Czech), First Time At(timestamp: 00:00:11:053) 17m 51.70s: info: convert work success for clip(00000.m2ts) 17m 55.18s: UILog: 0x927a6c0 work ctrl status 0->3 17m 55.18s: UILog: MsgWork:current work finish: 3 17m 55.19s: UILog: Run Work to end. 17m 55.20s: UILog: btn Visible: left btn 0 right btn 7 19m 11.76s: UILog: btn Visible: left btn 0 right btn 7 19m 11.85s: Source manager: open source flag:1,0,1,1,1 20m 03.37s: Exit process: processBeforeClose. 20m 03.37s: Exit process: clear temp folder. 20m 03.37s: Exit process: stop quality task. 20m 03.37s: Exit process: stop thumbnail thread. 20m 03.46s: Exit process: save config file. 20m 03.97s: Exit process: create jump list. 20m 03.97s: Exit process: save meta info to local file. 20m 04.00s: Exit process: stop running. 20m 04.09s: Exit process: finish MainUI. 20m 04.09s: Exit process: finish FreePref. 20m 04.09s: Exit process: finish AVEditWrap Release.
