How to rip Dolby Vision video track?
    I am trying to rip Dolby Vision video track unsuccessfully.
    First Man is Dolby Vision mastered disc, in the advance setting, I did select Dooly Vision option to copy in MP4 and TS profile passthrough as other options did not work either.
    From Mp4 rip:
    Video #1
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main 10@L5.1@High
    HDR format : SMPTE ST 2086, HDR10 compatible
    Codec ID : hvc1
    Codec ID/Info : High Efficiency Video Coding
    Duration : 2 h 20 min
    Bit rate : 57.1 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0 (Type 2)
    Bit depth : 10 bits
    Video #2
    Format : HEVC
    Codec ID : hvc1
    Bit rate : 6 606 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Color space : YUV
    Bit depth : 10 bits
    hi DeltaIV,
    yours,
      Thank you Wilson so much
      Not selecting passthrough!!
      It worked, I was able to extract the 2nd video track Dolby Vision.
      Thank you again
        Hi can you tell me what you use to play the file with DV? And what type of TV you have?
        Thanks
          hi DeltaIV,
          yours,
          Hi, now Dolby Vision is available in MKV too via MakeMkv... Will be available in your software? After that, which software do we have to use to play DV track? Thank you
            My apology to you all for the for not answering so long.
            My TV is Sony KD-75X8500G and player Sony X700.
            Only Sony X700 can play the Dolby Vision file.
            Currently, no PC/MAC software can play DV file connected to DV HDR TV can do the trick that I know of.
              do you say that x700 can play DV files? Or full ISO? Thank you
                The X700 will play DV MP4 only. Sadly the player will not recognize ISO
