Spider-Man - Across The Spider-Verse Read Error
    UHD Ripper Spider-Man - Across The Spider-Verse Read Error
    Brand new UHD disc - unwrapped the plastic and straight into the drive.
    ------ process working ------
    2024.06.10-23:29:23: opened i/o type 2
    2024.06.10-23:29:23: opening drive J
    2024.06.10-23:29:23: Supports Hybrid discs: YES
    2024.06.10-23:29:23: currentProfile: 64
    2024.06.10-23:29:23: got media type 15
    2024.06.10-23:29:23: got max lba 42636255
    2024.06.10-23:29:23: got disc type!
    44236 06.10 23:29:24.1(0x7b90)L: WorkManagerProcessInfo: Callback PROGRESS_FLAG_BEGIN percent=0%
    44236 06.10 23:29:24.1(0x7b90)L: work_status: in post: ui WorkData status changed to 8 WorkData_Start
    44236 06.10 23:29:24.1(0x3868)L: UILog: MsgWork:WorkStatus_Start
    2024.06.10-23:29:24: got disc type 40
    2024.06.10-23:29:24: type UHD BDMV
    2024.06.10-23:29:24: volume label SPIDER_MAN_ACROSS_SPIDER_VERSE
    2024.06.10-23:29:24: Disc Is Encryption 1
    2024.06.10-23:29:24: bd set region ?
    2024.06.10-23:29:24: got drive Inquiry!
    2024.06.10-23:29:24: drive Inquiry!
    2024.06.10-23:29:24: opened i/o type 2
    2024.06.10-23:29:24: opening drive J
    2024.06.10-23:29:24: Supports Hybrid discs: YES
    2024.06.10-23:29:24: currentProfile: 64
    2024.06.10-23:29:24: got max lba 42636255
    2024.06.10-23:29:24: got disc type!
    44236 06.10 23:29:24.6(0x7b90)L: WorkManagerProcessInfo: Callback PROGRESS_FLAG_RUNNING percent=0%
    44236 06.10 23:29:24.6(0x7b90)L: work_status: in post: ui WorkData status changed to 3 WorkData_Running
    2024.06.10-23:29:25: got disc type 40
    2024.06.10-23:29:25: Disc Is Encryption 1
    2024.06.10-23:29:25: internal path J:/BDMV/
    2024.06.10-23:29:25: aacs 1 bd+ 0
    2024.06.10-23:29:26: blu-ray 319B908BFF04C36E8E3ED86812357BAA9C12E0A8
    2024.06.10-23:29:28: cert BEE=0x80 same
    2024.06.10-23:29:29: main playlist 00000.mpls
    2024.06.10-23:29:29: MD5 5258AD751D87DCDFC502BCB487607C0B
    2024.06.10-23:29:32: drive info: HL-DT-ST | BD-RE WH16NS60 | 1.00!
    2024.06.10-23:29:32: check Support drive!
    2024.06.10-23:29:32: got data key
    2024.06.10-23:29:32: blupath v=94
    2024.06.10-23:29:32: blupath: movie disc
    2024.06.10-23:29:32: got playlists bdinfo.
    2024.06.10-23:29:32: fake and same playlists.
    2024.06.10-23:29:32: translate disc open.
    2024.06.10-23:29:32: Disc Analysis Type 0
    2024.06.10-23:29:47: update detector result.
    2024.06.10-23:29:47: got extended bdinfo
    44236 06.10 23:29:47.9(0x7b90)L: set source (1)(1)
    44236 06.10 23:29:47.9(0x7b90)L: after work start (1)(1)
    44236 06.10 23:29:47.9(0x7b90)L: run work (1)(0)
    44236 06.10 23:29:47.9(0x7b90)L: after run work(1)
    2024.06.10-23:29:47: info: create config(bluray2video)
    2024.06.10-23:29:47: info: crop value after clone: left = 0 right= 0 top=0 bottom=0 enable=0 mode=0
    2024.06.10-23:29:47: info: use profile(MKV.Passthrough)
    2024.06.10-23:29:47: info: bluray playlist(1),angle(0),chapter(1->16),BDAV(no),BDAVType(0)
    2024.06.10-23:29:47: info: 3D working_mode(disable), 3D format(sbs_lef_right)
    2024.06.10-23:29:48: Not Null 0, dwPlayList = 1, playLists size = 32
    2024.06.10-23:29:48: info: work_status(1) can_pause(1) last_error(-1) cancel(false)
    2024.06.10-23:29:48: info: stream input@ Video(4113)[codec(hevc) size(3840*2160) fps(24000/1001) interlace(0) duration(8406)sec opcode(copy) fmt(yuv420p10le) profile(-99) level(-99)]
    2024.06.10-23:29:48: info: stream output Video(4113)[codec(hevc) size(3840*2160) fps(24000/1001) interlace(0) bitrate(0) duration(8406)sec fmt(yuv420p10le) profile(-99) level(-99)]
    2024.06.10-23:29:48: info: stream input@ Video(4117)[codec(hevc) size(1920*1080) fps(24000/1001) interlace(0) duration(8406)sec opcode(copy) fmt(yuv420p10le) profile(-99) level(-99)]
    2024.06.10-23:29:48: info: stream output Video(4117)[codec(hevc) size(1920*1080) fps(24000/1001) interlace(0) bitrate(0) duration(8406)sec fmt(yuv420p10le) profile(-99) level(-99)]
    2024.06.10-23:29:48: info: stream input@ Audio(4352)[codec(truehd) channels(8) sample(48000) bitrate(640000) bitdepth(24) opcode(copy)]
    2024.06.10-23:29:48: info: stream output Audio(4352)[codec(truehd) channels(8) sample(48000) bitrate(640000) bitdepth(24) opcode(copy)]
    2024.06.10-23:29:48: info: SubMode(Remux) -- Display Only forced Subtitle(false)
    2024.06.10-23:29:48: info: work config prepare finish
    44236 06.10 23:29:49.0(0x75d8)L: WorkManagerProcessInfo: Callback dataType=PROGRESS_DATA_NOT_SET
    44236 06.10 23:29:49.0(0x75d8)L: WorkManagerProcessInfo: Callback PROGRESS_FLAG_BEGIN percent=0%
    44236 06.10 23:29:49.0(0x75d8)L: work_status: in post: ui WorkData status changed to 8 WorkData_Start
    44236 06.10 23:29:49.0(0x3868)L: UILog: MsgWork:WorkStatus_Start
    44236 06.10 23:29:49.0(0x3868)L: WorkManagerProcessInfo: EventInfoNotify: EVENT_MASK_MSG pszEventID= pszMsg=Conversion MsgType=0 dwStatusResID=0
    2024.06.10-23:29:49: info: begin render pin
    2024.06.10-23:29:49: info: nvml init, no apis 2024.06.10-23:29:49: info: recommand= 4032, Shrink support= 1, enable= 1, cuda_cap= 0 , cpu_count= 32
    2024.06.10-23:29:49: info: no nvml apis2024.06.10-23:29:49: info: helper_gpu_accel init end
    2024.06.10-23:29:49: info: begin create all filters
    44236 06.10 23:29:49.0(0x3868)L: WorkManagerProcessInfo: EventInfoNotify: EVENT_MASK_MSG pszEventID= pszMsg=Source( 00001.m2ts )
    2024.06.10-23:29:49: info: processing source(00001.m2ts)
    44236 06.10 23:29:50.0(0x75d8)L: WorkManagerProcessInfo: Callback dataType=PROGRESS_DATA_COMMON_SIZE_MBYTE
    44236 06.10 23:29:50.0(0x75d8)L: WorkManagerProcessInfo: Callback PROGRESS_FLAG_RUNNING percent=0%
    44236 06.10 23:29:50.0(0x75d8)L: work_status: in post: ui WorkData status changed to 3 WorkData_Running
    44236 06.10 23:35:50.9(0x75d8)L: WorkManagerProcessInfo: Callback PROGRESS_FLAG_RUNNING percent=6%
    44236 06.10 23:41:51.9(0x75d8)L: WorkManagerProcessInfo: Callback PROGRESS_FLAG_RUNNING percent=13%
    44236 06.10 23:47:51.9(0x75d8)L: WorkManagerProcessInfo: Callback PROGRESS_FLAG_RUNNING percent=21%
    44236 06.10 23:53:44.5(0x75d8)L: WorkManagerProcessInfo: Callback PROGRESS_FLAG_RUNNING percent=31%
    2024.06.10-23:56:56: read error: 11 16576 16275615 14771362 1
    44236 06.10 23:56:56.1(0x3868)L: OnDVDInfoNotify: error type 1
    44236 06.10 23:56:56.1(0x3868)L: WorkManagerProcessInfo: EventInfoNotify: EVENT_MASK_MSG pszEventID=Common pszMsg=Read Error: The result might be incomplete or cannot play back correctly.Please clean the disc and try again. MsgType=0 dwStatusResID=0
    44236 06.10 23:57:56.2(0x3868)L: User action for read error: 2
    2024.06.10-23:57:56: read error filling 0: 11 16576 16275615 14771362 1
    2024.06.10-23:57:56: error: m2ts demux sync error, pos:30219368640
    2024.06.10-23:58:00: read error: 11 16576 16275615 14787812 1
    44236 06.10 23:58:00.4(0x3868)L: OnDVDInfoNotify: error type 1
    44236 06.10 23:59:00.4(0x3868)L: User action for read error: 3
    2024.06.10-23:59:02: read error filling 0: 11 16576 16275615 14787812 1
    2024.06.10-23:59:02: error: m2ts demux sync error, pos:30253062336
    2024.06.10-23:59:02: error: m2ts demux sync error, pos:30253123967
    2024.06.10-23:59:14: read error filling 0: 11 16576 16275615 14878180 1
    ---Loads like this-
    2024.06.11-00:06:09: read error filling 0: 11 16576 16275615 15421056 1
    44236 06.11 00:06:09.3(0x7b90)L: wait finish (1)
    44236 06.11 00:06:09.3(0x7b90)L: after wait finish(1)
    44236 06.11 00:06:09.3(0x7b90)L: ------------------ convert work finished ------------------
    44236 06.11 00:06:09.3(0x7b90)L: WorkControl: return value is 0, user do not clicked cancel.
    44236 06.11 00:06:09.3(0x7b90)L: WorkControl: end user copy.
    44236 06.11 00:06:09.3(0x7b90)L: MovieServer: start copy file to server.
    44236 06.11 00:06:09.3(0x3868)L: WorkManagerProcessInfo: EventInfoNotify: EVENT_MASK_MSG pszEventID=Common pszMsg=Subtitles verification initiated. MsgType=0 dwStatusResID=0
    44236 06.11 00:06:09.3(0x3868)L: WorkManagerProcessInfo: EventInfoNotify: EVENT_MASK_STATUS pszEventID=Common pszMsg=Subtitles verification initiated. MsgType=0 dwStatusResID=1
    44236 06.11 00:06:09.7(0x3a7c)L: opened with zero ok.
    44236 06.11 00:06:10.3(0x3868)L: work_status: 0x168df480 work ctrl status 0->3 (PROGRESS_STATUS_CONTINUE -> PROGRESS_STATUS_STOP)
    44236 06.11 00:06:10.3(0x7b90)L: info, try to open file D:/Rips/Video/SPIDER_MAN_ACROSS_SPIDER_VERSE/Spider-Man- Across the Spider-Verse.theatrical.mkv
    44236 06.11 00:06:10.3(0x7b90)L: warning: audio info: index 1, codec_id 86060, channels 8, bitrate 0, sample_rate 48000, format 2, bit_per_sample 0, frame_size 40
    44236 06.11 00:06:10.3(0x7b90)L: info: open successed, iformat = Matroska / WebM
    44236 06.11 00:06:11.7(0x3a7c)L: opened with zero ok.
    44236 06.11 00:06:13.7(0x3a7c)L: opened with zero ok.[log repeated...]
    44236 06.11 00:06:20.3(0x3a7c)L: opened with zero ok.[3times]
    44236 06.11 00:06:20.3(0x7b90)L: work_status: in post: ui WorkData status changed to 7 WorkData_Successed
    44236 06.11 00:06:20.3(0x3868)L: ========current work finish: WorkStatus_Success========
    44236 06.11 00:06:20.3(0x3868)I: ui: UIDataForFinishedWork nWorkPrivateId= 0 nWorkType= 33554431 strWorkId= 0_16777218 nVideoWidth= 3840 nVideoHeight= 2160 nAudioChannelCount= 8 nHDRType= 4
    44236 06.11 00:06:22.3(0x3a7c)L: DriveX msg: remove media in driveX J.
    44236 06.11 00:06:22.3(0x3868)L: UILog: Run Work to end.
    44236 06.11 00:06:22.3(0x3868)L: app: action after work done NONE
    44236 06.11 00:06:22.3(0x3868)I: ui: message box exec scope begin "Some read errors occurred during the reading process, meaning the disc may not be able to backup correctly. For possible solutions, please refer to <a href='http://www.dvdfab.cn/faq?client_m=MDQtN2MtMTYtNTktMDctMGM6NzAtYTgtZDMtY mQtMGQtZTk%3D&client_e=c2NhdGNoZXJAc2hhdy5jYQ%3D%3 D&type=dvd_copy#faq_6&clientusertype=paid&c_bm=d vd fab&c_app=dvdfab12&c_id=67&c_sys=x64&c_ver=13019&c _ut=paid&c_app_from=official&c_rec=21&c_dt=click&c _wh=read_error_solution&client_t=1617666689_F2KWY3 FrVb&c_ad=dvdfab_dvdfab12_read_error_solution_paid &token=f126c4d56fc8b5a6d3e265790b4d135b' style='color: #0063FF';>How to handle read error problems</a>."
    Please use Copy - Clone mode to load the disc as source and see if you can clone it or not. If got the same error, please provide the dvdfab13.log file as an attachment to us. Thank you in advance.
      Copy - Clone: Same issue (occured at 37%). Log attached.
