I recently re-installed Windows 11 on the same PC I've been using and when I started copying and ripping blurays and UHD discs, both processes were half the FPS of what I remembered they were.
I saw max FPS of 55 to 60 with a bluray reading from a CD drive. When ripping a UHD from an ISO, I saw a max of 80 FPS.
These numbers are less than half of what I originally had under the same scenario.
I've tried all kinds of things, including re-installing DVDFab and chipset drivers, adjusting Pathplayer settings, and trying four different versions of DVDFab including 12.1.1.5 which confirmed what I was seeing.
My PC specs are as follows:
Asus ROG Zenith II Extreme Alpha
Threadripper 3960x Auto OC
Corsair Dominator Platinum 64GB @ 3600 CL16 (four sticks total)
Asus ROG Strix LC GeForce RTX 3080ti OC Edition
Samsung 980 Pro 2 TB NVME
Is there a known problem with the latest versions?
Is DVDFab not recognizing my system correctly?
What other steps can I take to get back my original performance?
I have some logs from ripping the same bluray disc with multiple DVDFab 13.0.1.x versions.
I also have logs from ripping the same UHD iso with 13.0.1.9 and 12.1.1.5.
I will include the logs and a screenshot from ripping the same UHD iso with versions 13.0.1.9 and 12.1.1.5.
Please let me know what else I can provide for a solution.
Thanks
Chris
screenshot is 12.1.1.5 ripping speed. 13.0.1.x versions speed was less than half of this.
Thanks
Chris
