jbinkley60 I am running UniFab 3.0.1.0 on a Windows 11 machine with a Radeon 890M GPU. UniFab crashes on startup and shuts down after the license screen. If I go back to UniFab 3.0.0.7 it works fine. I can provide logs, if needed. Here's the GPU info from 3.0.0.7.Thanks,Jeff
simon727 jbinkley60 I am running UniFab 3.0.1.0 on a Windows 11 machine with a Radeon 890M GPU. https://sharpedgeshop.com/de/blogs/knife-types/japanese-gyuto-chef-knife UniFab crashes on startup and shuts down after the license screen. Zahnimplantat Slowenien If I go back to UniFab 3.0.0.7 it works fine. I can provide logs, if needed. Here’s the GPU info from 3.0.0.7. As 3.0.0.7 functions correctly it strongly points to a software conflict introduced between that version and 3.0.1.0 Please provide the logs to accelerate the patch process for AMD users
KOR When I had like this, try to unistall it, check if the folder is realy gone, also delete the Temp folders, just look where there are in the settings, and when those are gone too, install it again. I hope this will help you.
jbinkley60 No, it's an issue with 3.0.1.0 because when I go back to 3.0.0.7 it works fine. Unfortunately I didn't download 3.0.0.8 or 3.0.0.9 to see which release actually started the problem. I don't have the download links for those versions. I am still mainly using DVDfab version 12 and still just testing 3.x of Unifab. Thanks,jeff
KOR Because I can't use AV1 at DVDfab 12 I started to use the "abyssmedia Video Converter Plus" and this app is doing it very well, even when some settings can't be tweked to my desire it comes close to it.
jbinkley60 I'll just wait and try again with 3.0.1.1Jeffjbinkley60Same issue with 3.0.11. Maybe 3.0.1.2 ?Jeff
jbinkley60 Still failing on 3.0.1.2. I tried uninstalling and reinstalling, same issue. i went back to 3.0.0.7 and it is fine. I've attached the last portion of the log so you can see the errors. I've added the qefab log which possibly points to the AMD 890M graphics card not being detected properly.Jeff
jbinkley60 I loaded UniFab 3.0.1.3 on an old machine I have running Windows 10 with an nVidia 2080 video card. It loads and runs fine. It won't run on my Windows 11 machine with the AMD 790M graphics card. 3.0.0.7 runs on both.Thanks,Jeff
jbinkley60 Version 3.0.1.4 is a winner on my AMD 890M system. UniFab now loads again without crashing.Thanks,Jeff
