First of I'm happy that I can download 4K from Fandango at Home (formerly Vudu) now in 6.2.6.0. Thank you @Wilson.Wang and developers!!
The rest of this is an FYI or informational post:
While I can't speak to what types of files StreamFab can see when trying to download from Fandango At Home (I can't seem to find in log what FAH presents to populate FS's selection boxes), I can only talk about what I see is actually downloaded when I select 4K. Therefore I just wanted to revisit the information I previously shared about Dolby Vision and HDR profiles of the downloads because Fandango At Home is different from HBOMax, Max, etc. at the moment.
(See -> https://forum.dvdfab.cn/forum/streamfab-support/streamfab/404024-streamfab-faq?p=455118#post455118 )
There are 3 Dolby Vision profiles I've seen used between HBOMax, Hulu, and UHD/4K Discs.
- SMPTE ST 2086 -> the file is HDR10 only.
- dvhe.05.0x -> the file contains Dolby Vision only
- dvhe.08.0x or dvhe.07.0x -> the file contains Dolby Vision, but also includes HDR10 as a fall back.
When selecting Dolby Vision/DV on downloads from Max/HBOMax, it resulted in a file using the dvhe.08.0x profile (DV with HDR10 fall back). So one single file containing both DV and HDR10.
Fandango at Home downloads for Dolby Vision is dvhe.05.0x, meaning Dolby Vision Only, no HDR fall back. So if you download a DV 4K from Fandango At Home, every piece of your playback equipment (TV, streaming box, anything in between) must support Dolby Vision to play it back correctly.
Selecting HDR10 for my download does result in a file with SMPTE ST 2086 HDR10 only.
So if I want both a DV copy (for my basement and family room TV setups) and an HDR10 copy (for my master bedroom setup), I must download two copies.
Also keep in mind this was the same behavior StreamFab exhibited when 4K from Dolby Vision was added, which has since changed. So maybe someone more knowledgeable than I could chime in and confirm if 4K with dvhe.08 or dvhe.07 are listed on Fandango at Home, because if they are, then there might be hope of Fab eventually downloading those.
