Downloading some films and series episodes from danish play.tv2.dk, and some finishes with error code 702.
Going through log files i find:
2025:11:19-20:40:50 0×0000640c [Info]: [default] “[CefMedia] Error opening input: Invalid data found when processing input\r\nError opening input file C:/Users/frank_cy3v3dn/Documents/DVDFab/StreamFab/Temp/outputTemp/DRM MPD/2025_11_19_20_29_41_6330666336626330643461336261313838653666323034316561653931363064/Period_00/Sub_00/st_00.trans.srt.da.\r\nError opening input files: Invalid data found when processing input\r\n”
…so the culpit is the danish subtitle file.
Retested, and download without subtitles work fine!
Not sure how to proceed with this, but suggest some way to ‘keep’ temp files.. It should be easy to ‘fix’ the subtitle .srt file, and just run it as external (supported by most players).
Add option to just keep .srt file without remux would be fine.
BR Frank
