I guess if nobody else is having this problem, then it’s something on my end…I see that my copy of “Velociraptor Rampage” has 6 subtitle options listed when opening with vlc…when i try any one of the subtitles, i can see each of the subtitle options are the same, but they are all from a different movie. I upgraded streamfab to 6.2.6.5 on my laptop and when i chose Velociraptor Rampage in tubi, the movie would not play in streamfab. It would pop up as if starting to play, but then disappeared, leaving me with that smaller streamfab window that allows me to download it. That window offered the option of having no subtitle or one english subtitle. I chose english subtitle but when playing the movie i see the subtitle is from a different movie…I compared that subtitle to the copy that has 6 subtitle options, and i see they are from different movies. I then used streamfab 6.2.6.1 from a different computer. It didn’t give me any subtitle options and did not indicate that subtitles were even available but when it downloaded the movie it had the correct subtitle.
Anyway, that’s basically what’s happening. I don’t know how to get the subtitle as srt, as I don’t see that option when downloading a movie. I would have to look for the instructions on how to upload log files, but I guess it’s not that important so for now I’ll just keep trying to fix the foreign language subtitles. I seem to have better luck with 6.2.6.1
