Windows 11
Version 7056 and newer (I did not try it on earlier versions, but it probably is good around 7054 or so)
If you are set to FFMpeg for your post processor, with MKV format, if the source has AAC audio, another interesting glitch pops up.
The resulting MKV file, the video portion of the file does not report a bit rate. The field is not even present in the file. Media Info doesn’t show it, the media player I use (MPC) doesn’t show it. You can see the total bit rate of the entire file (audio and video), and the audio bit rate, but not the video bit rate.
Yup, you guessed it, remuxing the file with MKVToolix puts that field back in correctly.
This bug was probably introduced at the same time as the cover.png attachment bug listed here:
https://forum.dvdfab.cn/d/474485-post-processing-issue-wrongly-named-coverpng-attachments/19
