Problems reading iTunes and other
    DRM Removal for Movies Problems reading iTunes and other
    Hello,
    after buying the DRM remover I have the following issues.
    1. The movies that have been bought in iTunes do not show up in the DRM remover after new movies have been added in iTunes.
    2. If I select to add movies from folder (since they do not load when select get from itunes)
    Harry Potter and the Philosopher’s Stone always fail.
    I have tested another program that I own and all works perfect.
    3. The videos that have been made DRM free can be loaded into the DVDFab converter or DVD / BD creator. However the subtitles in the files are not recognized.
    Again loading the files in another program and the subtitles show up and will be converted to play correctly as AVCHD.
    Anything you need? Soyou check on this issues?
    To load the new movies, we need to close iTunes and reload iTunes library again in DRM Removal, and the problem will be improved in the future version.
    For the problem, we will also have a try with the movie, and we also need some info of your source, please check your forum message, thanks!
    The dev is working on this.
      Thank you.
      Looking fwd to it
