Process Failed
    Process Failed
    Everytime i try the DRM removal process i get 'process failed'
    I am using the windows explorer method as my itunes librabry is not stored on the standard C:
    Did you try reading the f&q - http://forum.dvdfab.cn/showthread.php?t=30696
      Fab will fix this in future versions see thread here on same problem https://forum.dvdfab.cn/showthread.php?t=30732
        im not using itunes add method
        Even if i drag the file into the folder or use the windows folder option to add the file, i still get process failed. This is not the same error as you are getting by trying to get it to sync with your library.
          Try re downloading the same version this helped someone else.
            Try open your iTunes,and authorize your computer.
            Then use the windows folder option to add the file ,convert it.
            DVDFab log default location:
            DVDFab Player 5:
              Process Failed
              I was having this problem until I stopped the dvdfab programme and itunes going online. Once stopped, I now have only 3 files that cannot be converted.
