What about network based iTunes?
    DRM Removal for Music What about network based iTunes?
    My iTunes library sits on a MAC.
    My PC accesses the iTunes library over the network with no issues.
    Is it possible to have the DRM removal software communicate via the network to the iTunes server to do what it needs to?
    If not now, can this be a feature request?
    We will support DRM on mac in the future.
    For now, you can creat an iTunes library folder network share from Mac pc.
    My PC accesses the iTunes library on windows, you can add the movies -DRM-For movie - Add from windows- choose you network share folder -choose the movie that you want removal.
    For music, you need redownload files then remove the protect. We need the local file can not regnize it from itunes server directly.
    DVDFab log default location:
    DVDFab Player 5:
