Well- now only 2 os versions behind...
    So I updated all my Macs to 10.14 and of course drm removal pops up that only 10.11 and 10.12 are supported, then closes. So... I know the standard advice "don't ever update iTunes (or by extension OS X)". Any insights into if this is a super hard issue that will take years to accomplish, or if it's just a second rate priority that will get done when theres not much else to do?
    We are working for the DRM on macOS 10.14, it will be supported soon.
      Thanks for the update!
        Any updates on this? I'm in the same boat
            The latest version of DVDFab DRM Removal for Apple supports to run on the latest macOS, currently only audio section is supported. The developers are still working on the Video/Movies section.
