drm keeps freezing up
    DRM Removal for Movies drm keeps freezing up
    Ok I have gotten some to work, 3 movies from iTunes, one is older movie devils advocate it worked. The other 2 movies are new bad boys forever and the gentlemen. The two newer movies are giving me the problems. logs included.
    Hi There, just to say at the moment itunes version 12.10.6.2 will not work with DRM removal,try version 12.9.2.6 that works fine for me with all films.Until the team can support 12.10.6.2 & later, this is the best work round.Hope this helps.
      Thanks, not sure why it only happens on the one PC that I use dvdfab on most. My other one works fine. Im using version 12.7.3.46 and it works great, Ive wiped both drives on the problem pc and reinstalling everything it should work after that.
