Incorrect Parameter
    Incorrect Parameter
    I burned a dvd with DVD Creator, but I get a Playback Error: the Parameter is Incorrect.
    Will not play on computer or TV.
    Please use DVD Creator to convert the video file and save it to your local hard drive first, and then use a software player to play it to see the result.
    If all okay, then you can load the copy to DVDFab Copy-Clone/Burn mode to burn again. Slow down the write speed in DVDFab Common Settings > Drives > DVD Write before you start the burning.
      Thank you, I will try that.
