Got it to work
    Got it to work
    Okay figured out after uninstalling reinstalling editing the registry, that is was the last update to fab. I always keep a older version I had upgraded my subscription to DRM for apple, as it turned out to be Not upgrading that but the new version of Fab from the 13th. I used version 11.0.8.8 and was able to download the DRM module on two separate computers and it worked. Now an then when a update comes out there's always another bug from fixing the bug. Logs from the older version included. I had a ticket from support and explained that doing everything they suggested the new version at latest on my two pc's would not work. So maybe I'm thinking should I update the older version? Or wait until the bug is fixed.
