DVDFab 6 Product Functionality
This is a sticky topic.
    All DVDFab Products are contained in one installation package and are available as a fully functional 30 day free trial.
    We thoroughly recommend that you try this before you purchase any DVDFab Product so that you are sure that the Products which you purchase meet your needs.
    DVDFab will neither copy nor remove copy protection from software BD/ DVD's/CD's, games BD/DVD's/CD's nor music BD/DVD's/CD's.
    It is designed for copying, copy protection removal & encoding of BD/DVD video/movies only.
    The reason that most of us use DVDFab over products like Shrink is that development on Shrink has ceased ages ago, and hence new DVD titles that come out with new copy protection schemes cannot be processed.
    Whereas on the other hand, DVDFab usually has a beta release within a few days of the title release which removes the new protection.
    DVDFab HD Decrypter - Free Product
    DVDFab HD Decrypter will rip a DVD to a hard disk folder or an ISO image file, removing all copy protection but without compression. DVDFab HD Decrypter removes all the DVD protections (CSS, RC, RCE, APS, UOPs and Sony ARccOS) and part of Blu-ray protections (AACS, RC, UOPS and BD-Live) while copying.
    This Procuct will continue working even after the expiration of the trial period and is totally FREE!!
    DVD to DVD - Purchased Product
    DVD to DVD will remove all copy protection and copy a DVD to another DVD, a Hard Disk Folder or an ISO file with or without compression to either a Dual Layer or Single Layer disc. DVD to DVD allows you to copy the entire disc bit-for-bit or select only the titles/chapters that you want.
    This Product also allows you to split episodic/season DVD movies or TV series.
    It also allows you to customise your DVD to include only your favorite titles, audio tracks and subtitle tracks.
    You can keep the menus or remove them or combine two or more DVD's to one disc.
    How you want to personalise your DVD is up to you.
    Blu-ray to Blu-ray - Purchased Product
    Blu-ray to Blu-ray will remove most copy protection [coming soon BD+ Support] and copy a Blu-ray disc to another Blu-ray disc, a Hard Disk Folder or an ISO file with or without compression. Blu-ray to Blu-ray allows you to copy the entire disc bit-for-bit or select only the main movie.
    It will also burn any Blu-ray disc from a hard disk folder or an ISO image file.
    DVD to Mobile - Purchased Product
    DVD to Mobile will take the output from a DVD, a DVD structure held on a Hard Disk or an ISO file and produce a file to the specifications outlined in the profile chosen.
    There are a wide range of profiles for different devices included but you may also modify the existing profiles or create custom profiles to meet your specific needs.
    File to Mobile - Purchased Product
    File to Mobile instead uses a wide range of video file formats as the input instead of the DVD structure as in DVD to Mobile and has the same wide range of output options.
    File Mover - Purchased Product
    File Mover assists users in moving files to their mobile devices. Currently it supports iPod, PSP and ZUNE, and it will support more devices in the future.
    Why don't you just download and get fully acquainted with these options during the 30 day fully operational trial period? Beta and Production version downloads are listed at the top of the main forum.
