Fix Read Failure on Used DVDs
    Occasionally I have had several Movie DVDs that the computer has failed to read. Very frustrating. Observation of the disc surface indicates no flaw in any case. The employee that sold me the used movies had very carefully added some solution to the disks and put them into a cleaning machine. However, simply washing the disks with a little hand dishwashing-water solution, rinsing and drying them solved the reading problem. It is a pretty good bet I am not the only DVDFab fan with this problem.
    Editor's Note: This is a good tip. I have noticed the same thing with "previously viewed" discs.
