Queue DVD Sources (ISO or Folders) for Mobile Conversion with a Batch File (Fabv6218)
    Editor's Note: Thanks to Bill for updating this useful guide. This one is for DVDFab v6.2.1.8 or later. For earlier versions of DVDFab, use the previous version
    Queue DVD ISO Files or Movie Folders to Mobile Conversion Using a Windows Batch File – Updated for DVDFab v6.2.1.8
    Features:
    • DVDfab v6.2.1.8 has a completely revamped and powerful command line capability. If you do any repetitive conversions in DVDFab this is a real timesaver.
    • Very general purpose. All key variables can be initialized using set statements.
    • ISO batch file recursively searches directory looking for ISO files
    • Forced subtitles work (i.e District 9 and Angels and Demons)
    • Added comments to the batch file. Please read them.
    This windows batch command is useful if you want to convert a large quantity of ISO files or movie folders to a mobile format. DVDFab has a queue capability but you have to load the queue one file at a time. It analyzes each movie as it is loaded. This is acceptable if you have a small number of movies to convert. There is no drag and drop capability to load the queue at one time with a large quantity of movies. For example, if you have a new player that uses a different file format and you want your movie collection converted to that format the batch command works great. It takes only a few minutes to setup. You will need to edit the windows batch command to meet your specific needs.
    There are 2 different batch commands. One is used for converting ISO files. The other one is for converting movie folders.
    Remove .txt from .bat files. Forum does not allow .bat files.
