EDITOR'S NOTE: Thanks to billbell52 for this handy utility. It is very professionally made and documented. The DVDFab developers are currently working on enhancements to the command line interface that may require updates to FabBatch in the future. The download files have been scanned with Kaspersky Internet Security 2010 and found free of viruses or malware of any kind.
I created an Excel Addin that runs DVDFab in batch mode.
Why use FabBatch?
FabBatch is useful if you want to convert a large quantity of ISO files to a mobile format. DVDFab has a queue capability but you have to load the queue one file at a time. It analyzes each file as it is loaded. This is acceptable if you have a small number of files to convert. There is no drag and drop capability to load the queue at one time with a large quantity of files. For example, if have a new player that uses a different file format and you want your movie collection converted to that format FabBatch works great. FabBatch takes only a few minutes to setup.
You can find the documentation and install executable attached below.
Please let me know if there are any errors in the documentation.
Here are the FabBatch executable and documentation files. The documentation is a pdf.
Why use FabBatch?
