Disable MetaData Title
    Hi I want to disable writing MetaData Title when I create.
    When I'm creating MKV file from my DVD, DVDFab create the file with a MetaData title wich is different from the name file. How do I say to leave it blank ?
    When you notice that the file name is not correct for the file, you can use the Fix Match feature to correct the name first.
    To disable the Meta info, you can do it it in Common Settings window, see image attached.
