Small Problem with caption playback
    Video Playback Small Problem with caption playback
    I can't turn off close caption playback on Max 2. Playing iso file with another device works fine. Seems like a bug. Not a huge problem, but annoying none the less.
    Is it happen on any iso files?
    1.Please check the menu setting -subtite setting, closed subtitle display.
    2. Press the subtitle button on remote, still the subtitle is set off , to see if the subtitle could be closed.
    DVDFab log default location:
    DVDFab Player 5:
      Just keep pressing subtitle button. I go into the menu to turn them off and they keep coming back. Subtitle button on remote, just press to get through the choices until you reach off.
