DTS Audio and Accurate Chapter Selection
    BD Ripper (3D Plus) DTS Audio and Accurate Chapter Selection
    Hi. I rip blu-ray to M2TS. I usually don't have any issues with 8.0.8.5 version. Anything after that has had problems with audio and then image format.
    Whilst the 5.1 surround encoding delivers a quality sound, I would like to see DTS HD encoding option added. Listening via the disc with DTS is a superior listening experience and would be great if possible.
    The other thing is accurate chapter selection. Streaming a whole blu-ray disc without chapters creates lagging issues. Rewinding/fast forwarding options are limited for a full-size stream, even with a 5Ghz connection. I have found selecting chapters in the rip much more successful and usable. However, the chapters selected by your software is not accurate. It sometimes chooses a chapter end mid-sentence and/or action and not at the end of a scene. Improvement here would make a very good ripping experience into an excellent experience.
    Thanks
    If you select any of "m2ts.audiocopy" profiles or "passthrough", you will get whatever audio format is in original content. Just make sure "Remove HD Audio" box is unchecked. If you source content contained DTS-HD MA audio, that's what you will get in output.
    Are getting chapters in m2ts? Can you please post MediaInfo for one of them here.
    sigpic
