BD to AVCHD conversion
    BD Copy BD to AVCHD conversion
    Is it possible to set the DVDFAB to convert a DB to AVCHD?
    This will cut down on the cost of using the BD blank disks and still give the HD performance.
    What I have in mind is the setup like BD to DVD - one click function.
    @wsl45
    You can select BR or AVCHD structure in Common Settings for BD copy. You can also compress down to DVD DL size (BD9) with AVCHD structure, AVC encoding, without major lass in quality. You have to playback BD9 on Blu-Ray player though.
    sigpic
      Originally posted by IPopov50 View Post
      @wsl45
      Thanks for the advise - works well.
