Request to set manually Audio and Subtitle Stream on BD
    I would like to be able to set automatically which Audio and which Stream starts automatically.
    The programm already does write a command for this but you have no selection function if you have a lot of audio and/or subtitles on your BD so it would be cool to have this function.
    I think it would be useful as it is quite complicated to do this with another programm.
    By the way it should be able to create a function to set/change Auto Stream/Subs after having finished to shrink a BD because it is possible to do so.
    Yes - Certainly would like this feature ASAP
