'Custom' Compression
    DVDFab (UI/General) 'Custom' Compression
    Hello,
    Instead of having just DVD9 & DVD5 Compression for DVD's.
    How about a 'Custom' Compression.
    For Example, 3000 MB (which is 3 GB).
    You could Compress the FULL DVD, or you could take out the Trailers etc, that you did not want.
    You could keep the Menu's & Main Movie, etc.
    Please reply to this thread, if you would be interested in this feature being added.
    I think this is something that I would really like, How about you ????????
    Do you mean this option that allows you to adjust DVD5 and DVD9 to almost any size or do you mean something else?
