I have a Radeon HD5850 accelerator which uses double precision arithmetic. It can use "OPENCL" and programs written to OPENCL run fine on both nvidia and ati as shown here
I run that boinc project milkyway as shown in the above url and my HD5850 gives better performance than my GTX570 (look at Flops below)
6/24/2012 7:38:11 AM | | NVIDIA GPU 0: GeForce GTX 570 (driver version 301.42, CUDA version 4.20, compute capability 2.0, 1280MB, 1132MB available, 1425 GFLOPS peak)
6/24/2012 7:38:11 AM | | ATI GPU 0: Cypress (CAL version 1.4.1720, 1024MB, 991MB available, 4176 GFLOPS peak)
I suspect that dvdfab is not using opencl. They are probably using the CUDA libraries and tools. Not all boinc projects support ATI accelerators as the projects needs may not be adequately supported.
There is a discussion of ATI 7000 series and opencl
I've been asking for this feature for years now. I doubt it will happen. They claim AMD does not "allow" (can't recall the term they used) for encoding, only decoding in it's drivers. I started asking back on my old 5870 card. Bumped up to a 7970 now.
Ended up installing my old GeForce 8800GTX and enabling the PhysX hack to get CUDA supported. Works like a charm.
AMD said a few days ago that most devs don't support OpenCL as it's too hard to program for. They have started pushing a new format. See if I can get you link in a bit.
Edit: K, maybe not a new format, but they admit to OpenCL's issues openly.
Quick quote...
"This can already be achieved using a programming language called OpenCL, but AMD believes it's too tricky to code and is putting mainstream developers off."
Ati Readon HD 6000 serie and down does not have any hardware encoding for any video format. What people have done is writting own encoder that using OpenCL or DirectCompute. But in AMD Readon HD 7000 Serie it contain AMD frist real hardware encoding.
Visit AMD Developer Central, a one-stop shop to find all resources needed to develop using AMD products.
Open Video Encode
The OpenVideo Encode library provides an OpenCL API that leverages the video compression engine (VCE) on AMD platforms for H.264 encoding. This sample illustrates the use of the OpenVideo Encode library to encode video in the H.264 format. The sample takes a YUV file as input, encodes it using the OpenVideo Encode library and then saves the compressed elementary stream to disk.
url for example code : http://developer.amd.com/wordpress/m...openEncode.zip
I hope dvdfab will build in support for amd hardware encoding. after all the documentations are now open how todo it
